x300 wont start
Old 01-04-2011 | 12:51 AM
ramitin2's Avatar
Default x300 wont start
hi everyone im new to this so i need your help...
i have a 95 3.2 x300 stood a couple of months as i lost the keys recently found thank the lord...
charged the battery but will not start engine is turning over strong smell of petrol from the exhaust but will not fire....thanx
Old 01-04-2011 | 08:42 AM
sparkenzap's Avatar
ramitin2:
I have been "called out" on this test before, but I am pretty sure it is vald. Does your tach indicate 250-400 rpm while cranking? If not, that can be a sign of a bad CKPS. That the crank sensor on the front of the engine. On the other hand, I would not expect the fuel injectors to fire if there was no CKPS signal.
So, then either you are probably getting no ignition OR you have a badly leaking fuel injector. I bet on the lack of spark.
Old 01-05-2011 | 08:34 AM
ramitin2's Avatar
hi ross
thanx for your input ...i have put new injectors into it recently and the tacho is moving on turn over but no fire will change spark plugs thanx allan
99xk8guy
05-28-2024 10:36 PM
JarodL
03-07-2024 02:39 AM
aholbro1
08-05-2021 06:02 AM
Bones
09-08-2015 09:34 PM
AL NZ
09-04-2015 09:39 PM
Quick Reply: x300 wont start
