X300 xjr...wont start....yes another one!
have a 95 xjr
Ive been away a while so battery was flat but now all charged
power for everything....lights....seats etc....everything lights up on the dash....does its checks....then dash lights goes out as you expect
except the check engine light ?
then turn the key....nothing....not a peep...no starter motor click....no dimming of power.....simply nothing at all !!
another odd thing is that my key fob isnt unlocking or locking the doors.....related?
wot should start checking for
started up fine last time i used it before long break
Im only home for another day so would like some suggestions as to what to check for
It is likely to be either the + connection or the ground. Check the ground strap between the engine bellhousing and the chassis, by disconnecting and cleaning. Also check power to the starter relay at the left front of the engine compartment, first on the right looking forward, then at the starter. Obviously someone has to be turning the key to start osition for the last two.
battery seems to have power enuf as lights work full strength....and dont dim when i turn key...just nothing happens when i do
fob lights seem bright but will change battery
dont know how to reset the immobilizer but from what your saying there is clearly a way....I will google it
was also thinking it might be inertia switch from reading some other threads so will also checkiit
keep em coming ....you never know ...it might turn out to be something else
any member living in southend on-sea essex UK who fancies dropping round to my place and help me scratch my head over a cup of tea will be very appreciated
Ok will look for that
are you tellinh me 1800 irish quid to tax an older car like ours....Phu& me!
thats criminal extortion....gangsters arent that bad
as for inertia switch I got to it and it wasnt tripped....so thats out
my dash light up on turn of key no probs....then I wait a few seconds...most ligts go out as normal but check engine stays on
if l lock car with key.....fob unlocks it.....but wont lock it
would appreciate a guide to forum location for the reprogramming if you could
thanks to all
just found the official jag data on another thread....as described in your links also
driver door and boot open
turned on ignition
pressed the valet switch five times.....1 beep and lights flashed
pressed lock button on trans fob once
all done right?
Nah!....didnt have it....so got out of car and shut doors and trunk
test....
when fob lock button pressed i get a beep but it wont lock doors.....
lock doors manally ....then fob unlock button will unlock doors and same from inside if door buttons pressed down manually
Unlock the doors manually....get continuous beep until l press fob unlock....then beep beep
hmmmmmmmm
and still wont turn over
turned on ignition
all done right?
test....
hmmmmmmmm
thanks to all
turned on ignition
all done right?
test....
hmmmmmmmm
turned on ignition
all done right?
test....
hmmmmmmmm
out i go again....one last try.....gettin cold out here
thanks
but got a feelin with my luck its not going to happen
EUREKA....
I owe you a drink
it was the last press of the valet key sorted it
but still no start :-(.........ah well....one less thing....now to look for bad earths or blown fuses
many many many many thanks
Dave
thanks
EUREKA....
I owe you a drink
Dave
many thanks to sogood and all who chipped in and got me sorted on the fob reprogramme but the main issue of a no start is still there
key fob does what is should as far as opening and closing door locks so Im assuming security system isnt having anything to do with the no start issue now
so now situation is simply that nothing happens after key in / turn to power up the guages / wait a sec or two / gauges go out exept the 'check engine light' ....turn key to start ....and absolutely nothing.....no click no turn....nothing at all
Dave
Dave
Yep! you are right.....common sense place to start ...Unfortunately I ran out common sence earlier in the day
thank you
also.....
Code readers for our cars (as one might help if i used it)....
As i recall there was a split year in the model range when OBDII came in or did that just happen when the X308 went into production
I thought that early X300 did not have OBDII and later ones did with split 94 95 didnt as i recall....then 96 97 did
anyone confirm
thank you
also.....
anyone confirm
Dave
Dave
I could see that might be an issue but it didnt have any effect on my starting on the key either when I put the shifter in neutral to start it or when wiggling it about in park....I can hear the switch clicking in n out in park and the whole thing seems to work ok
As Im now back in Ukraine Im going to have to either leave this for another few months til l next get back for more head scratching or have some mobile car sparky over to sort it....and I really hate doing that
going to google for code reading methods for 95 xjrs and see if that can help
'95 x300's for the North American market do have an OBDII port. I'm uncertain if OBDII was supported on '95's elsewhere. On North American market cars, the port is located beneath the steering wheel to the right flush against the center console. Owners of '95's report having no issues reading codes, although some say they can't extinguish the check engine light.
Im geting a new battery anyway as the one I have in is man enough but not the right shape....however
having got to the points previously mentioned ...key in...turn...gauges lights run sequence...they go out...only one left is 'check engine'
and then even with headlights full lights on...when i turn the switch to crank position nothing happens at all and the head lights dont dim a jot...its like the cranking circuit is not getting any signal let alone power
only thing that happens when i turn is the air bag light falshes on while key is held to crank but that is normal
terminals are all clean corrosion free and tight...my gear isolator is working i think as it clicks in park when shifter is wiggled in the notch at the top
will check to see if the ignition barrel hasnt dropped a connection
im new here but i have some experiance with jaguars x300 i have 3 off them 1995 1996 1995 xj6. 1st try to disconnet the battery cables off for about 15 minutes and back in... or souns like a bad body processor module i have pleaty off spare parts let me know if you need any part parting out all off mine thank you can email me at huileca@gmail.com
I have had the car diconnected for several times for that period and still didnt have it
as for parts Im guessing that with me being in the UK then your parts might cost a bit to post from CA to England
But thanks for guide....doesnt mean to say it isnt the problem....might need to source one in UK tho
