X306 UK ECU vs. US ECU
if i am not mistaken immobilizer programming is in the security module and not the engine module.
there are different part numbers and from my understanding the 2 most important factors are ensuring to get the correct one for XJR6 and that the last 3 numbers are the same.
one thing to note is i know the US has an EGR system which i don't know if UK had. i know AUS did not.
also to note even if they are interchangeable or you get a US module you may need to get it calibrated to run your car correctly.
