X308 driver's seat belt in X300?
I don't think so.
The X308 seat belt is different and the design of the B post internally is different between the two models.
I rebuilt my X300 in to a X308 body shell and I had to get X308 seat belts as the X300 belts would not fit (I can't remember the specifics).
So I would assume it's the same the other way around.
Interesting. What about the seats?
I don't think so.
The seats are structurally the same so will bolt straight in. However, the electrics are very different.
I used a set of XJ8 seats but I removed the leather and foam from them and fitted that to the X300 seat frames and electrics. A bit of modding is required but it's very doable.
Additionally the seat belt warning wring is different (Normally Open v Normally closed) and will need to be modified or disabled.
Don B (09-01-2016)
FS[SouthWest]: X308 Rear Sway Bar Bracket
SD96XJ6L
06-15-2016 06:10 PM
