XJ X300 headlamp removal
sorry if I've missed the useful post but searching the above subject didn't produce relevant X 300 information. Looking to replace the bulbs on a 97 XJ 6- can get the trim rings off no problem but no clue how to get to the bulb. r. Looking at it for 15 minutes with a beer in my hand only lead to loss of the beer.... thanks- d
Received 10,878 Likes
The actual *bulbs* are replaced from behind.
Open the hood. Grasp the fixture/socket and give it a quarter-turn (maybe half-turn?) counter-clockwise to disengage it from the headlamp itself.
For easier access you may have to remove the black plastic splash sheilds which partially obscure the back of the headlamps
dmpsqrd (06-09-2013)
Each lamp assembly (no separate lens, per se) has three pegs which simply pop in/out. It's a ball-and-socket type of thing.
Get your fingers behind the lamp and give a good hard pull....and out she comes! Or.....use a long, well placed screwdriver behind the lamp to lever it out.
From time to time the pegs have been known to break, making the job a bit nerve wracking
Reinstallation is simply locating the pegs over the sockets and giving the lamp a good thump.
Cleaning the lamps in the kitchen sink really makes them sparkle and improves lighting. Warm water, a drop of dishsoap inside, slosh-slosh-slosh, repeat a couple times, rinse, let dry.
The following 2 users liked this post by Doug:
dmpsqrd (06-09-2013),
littlelic69 (06-21-2013)
dmpsqrd (06-10-2013)
The following 2 users liked this post by plums:
dmpsqrd (06-10-2013),
aholbro1
08-05-2021 05:02 AM
42Ajd
12-30-2015 09:45 AM
