XJ6 1997 - cutting out
Old 11-18-2013 | 09:46 AM
markymark's Avatar
Default XJ6 1997 - cutting out
Having trouble with jag 3-2 1997 keeps cutting out when slowing down to a halt any ideas b4 i take it to garage
Old 11-18-2013 | 12:59 PM
Welcome to the forum markymark,
I've moved your question from UK Region to X300 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old 11-18-2013 | 01:56 PM
70z28's Avatar
Hi mate welcome to the forum this can be a number of problems from plugs coil packs an sensors best thing to do is get it pluged in. does the check engine light come on before it stalls ?
Old 11-18-2013 | 02:46 PM
RJ237's Avatar
It could also be that the throttle body needs cleaning.
Old 11-18-2013 | 03:27 PM
Ziggy's Avatar
I did the sparkplugs and cleaned the TB the first time I had this issue. It came back recently & 5 minutes with a rag and some carb cleaner did the job! :-)
Old 11-19-2013 | 04:27 AM
markymark's Avatar
yes the light does come on
Old 11-19-2013 | 07:52 AM
AllanG's Avatar
Do you have access to an OBDII scanner? Knowing the trouble code would be helpful in diagnosing the problem. If you don't have one, go to your local Autozone or other parts store and they will usually scan it for you for free.
EDIT: Whoops, just noticed you were back in Blighty, still I would try a parts shop and see if they'll do it.
Old 11-19-2013 | 03:33 PM
70z28's Avatar
I had mine pluged in with the same fault an it was the throttle position sensor but this may not be the case with yours you need to get it plugged in an google the codes
DevonDavid
10-27-2021 07:19 PM
Kevin Burnaby
06-28-2020 08:04 AM
42Ajd
12-30-2015 09:45 AM
xjrjag
09-27-2015 01:53 AM
Boeingtravel95
09-14-2015 05:01 PM
Quick Reply: XJ6 1997 - cutting out
