XJ6 Battery Change
Received 10,892 Likes
Could be a failing ignition relay. That relay is a common fail point and would explain your intermittent no start condition. In the engine compartment on the right hand side, there is a fusebox. Nearest to the windshield on that fuse box is a blue relay. That's the troublesome little bugger you might want to look at.
I investigated this problem also and I discovered that the (+) cable from battery to the starter was extremely loose. So, I disconnected the (-) cable at the battery and tighten the nut nice and snug. You will need a long 1/2" ratchet boxend combination wrench. You can reach from above on drivers side between valve cover and fuel rail close to firewall. This solved my issue and hopefully its the same for you. Goodluck!
Hi guys thanks for all the input. So here's the latest checked the processor module. And gems unit on passenger side kick panel. The gems had corrosion on contacts like it had gotten wet. Replaced it with one from junkyard. Still no luck. Well I decided to try something.
I jacked up the car on right hand side passenger side to look at the contacts on the starter. Everything was tight
But I sat in the car and tried the cat. And bam it started. Again And again.
I let the jack down and no start. I jack it up on passenger side and bam I can start it. Will someone please help me and tell me what issue I'm having??
Thank you.
Thank you.
#30
The diagrams show an "inclination sensor" mounted in the left front area of the trunk.
I dunno how to test it or if it would cause a "no start" but I'll try to find out.
#31
As my neighbours have never allowed me to forget from an incident in the early hours of the morning a few years ago, the "inclination sensor" sets off the alarm on a UK spec X300 when the front of the vehicle is raised by more than 15 degrees.
On UK X300's it's activated with the alarm system.
The alarm setup varies around the different World markets and this may not apply elsewhere.
Doug,
Right, multiple variations. The text of the service manual and the schematics are in direct conlfict as to USA market cars having this sensor. Schematics show it; the text excludes it.
I dunno.
If Frank's car has one, it'll be on a metal bracket just below the left trunk lid hinge...as far as I can tell.
In the text of the service and owners manuals I couldn't find any explicit explanation as to which alarm features can inhibit engine cranking.....other than the "immobilizer" igntion key which we know is not used on USA cars.
I'm stumped
#33
The only thing that I can think of, Frank, is to A) see if your car has the inclination sensor (see my reply to GGG) and B), if it does have this sensor, unbolt it from the car and have a helper tilt it in various directions while you try starting the engine.
If this doesn't pan out I think you'll have to take the car to a capable auto electrician and have him work thru the system....and it's virtually a given that he'll need to have the schematics and manuals to sort out anything related to the security system.
#34
Why isn't it just a starter ground problem ?
Bending the chassis makes ground contact.
Try a voltmeter from the starter body to a known good ground - if you get +12V when you try to crank it is the starter ground strap.
This thread has a quick fix if that's the problem
https://www.jaguarforums.com/forum/x...esolved-84962/
#35
#37
Hello guys! I've been having the same issues. I found the connection from the battery loose. Now that I have fixed that it turn over crank after numerous tries. I have done some research and found out that the crankshaft position sensor if faulty will not allow spark to the spark plugs by way of the ECU.
#38
Great news. Gotta love an easy fix. Steve gets a medal for the ever-important "go back to the basics" advice :-)
#39
Again want to thank Steve for helping me get my cat running. So now that it starts and I can drive it.
I am having some issues and I was wondering maybe you guys can help me solve them.
When I step on the gas the car bogs like stalls.
Loss of power. So I have to back off on stepping on the gas. Then step on it again. And it goes.
Any advice ?
Any advice ?
