XJ6 dead!!!!!!
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
It would have a been a shame to scrap the vehicle - looks way too good for that.
Received 13,255 Likes
gr8punkin (05-11-2020)
The following 3 users liked this post by OldSchoolJag:
Hi all, I'm ordering all of the bits and pieces I need for the new engine intake and exhaust manifold gaskets etc. I'm curious if you folks think I should pull the pan on the new engine 80,000 miles and put new gaskets on the lower end or am I more likely to create leaks that weren't there in the first place.
I want the new engine to not leak at all, and I'm hoping your sage like wisdom can help me out here.
Thanks all.
John
Thanks all.
John
Thanks all.
John
Thanks all.
John
My personal opinion is that at 80,000 miles and 20+ years it would be prudent to change the oil pan gasket, front and rear crankshaft oil seals, the intermediate shaft oil seal, the oil galley plug O-rings and washers, all the seals and gaskets on the oil filter housing/cooler pipes/bypass pipe, the dipstick tube sleeve, and consider replacing the knock sensors and oil pressure sender if you can find new ones at a good price. since it will never be easier to replace them. I'm sure I've forgotten something - hopefully others will remember.
Cheers,
Don
gr8punkin (05-19-2020)
Shop all of our forum sponsors, including Jagbits, Welsh Enterprises, SNG Barratt, and Coventry West, and also check Rock Auto, PartsGeek, FCP Euro, and jaguarmerriamparts.com. For some of the gaskets you may find OEM and aftermarket options that are much less expensive than Jaguar-branded parts.
You can look up part numbers at jaguarlandroverclassic.com.
Cheers,
Don
Cheers,
Don
#30
That's a great example of a catastrophic failure! If you have a car with "special needs" never lend it to anyone. They will never check any fluid levels. Most non enthusiasts are not aware that older cars need to have fluid levels checked at every fuel fill up. All of my older cars use oil, usually a quart per thousand miles. If you get the oil changed every 3,000 miles, you'll be three quarts low before you have the oil changed.I had an old F250 pick up that would use a quart of oil every fifty miles! It didn't even smoke noticeably under normal driving ( no, it wasn't leaking on the ground, it would have looked like the Exxon Valdez!) On a round trip up to Santa Rosa to buy a replacement engine for the truck, I used five quarts of oil! I stopped and added a quart every fifty miles. Nobody else would do that. If I would have lent that truck to anyone they would have burned or blown the engine before they realized ( or cared!) that they had run low on oil.
Cafcpete (05-20-2020)
#31
Don B (05-20-2020)
Daniel Smith
07-25-2022 06:45 AM
Daniel Smith
05-26-2022 02:55 PM
hauserplenty
US Western
03-24-2020 03:18 PM
