XJ6 Diff into XJR? Will the electronics go nuts?
I am wondering if anybody here has swapped a diff from a normally aspirated XJ6 into an XJR. I like the idea of having 3.58 gears instead of 3.27. I am wondering id ABS/Traction control or Transmission control unit will go nuts. If programming needs to be done, I have IDS/VCM setup.
someguywithajag (02-09-2017)
Received 10,952 Likes
I made that swap on my XJR/6. No problems of any kind. Noticeable (but not earth shattering) improvement in acceleration, about 200 rpm higher at 70 mph, loss of about 1 mpg fuel economy at highway speed
I was lucky to find a rebuilt 3.58 diff with limited slip for just $400, including shipping, on Ebay.
The following 2 users liked this post by Doug:
juha_teuvonnen (02-03-2017),
XJRengineer (02-04-2017)
Also I assume you'd have to find an XJ6 differential with limited slip if that matters to you, otherwise aren't the typical XJ6 differentials just an open differential?
I hope my differential never wears out due to cost, but if it does, this is on my list of options to consider. MPG is already awful, so 1 MPG lost wouldn't really matter
