XJ6 - EGR valve
Old 07-14-2014, 12:46 PM
ocean_view's Avatar
Default XJ6 - EGR valve
Hi all,
'97 XJ6, getting EGR check engine.
Gas mileage also not as it used to be too.
1. Is there a recommended EGR brand for replacement?
[Standard Motor Products, Airtex, or ACDelco]?
2. Should I also replace the gasket too?
Old 07-14-2014, 02:17 PM
RJ237's Avatar
Received 2,819 Likes on 2,246 Posts
Try taking it out and cleaning it first, that's all mine needed.
Old 07-14-2014, 02:56 PM
ocean_view's Avatar
Thanks RJ.
Any recommended cleaners?
Also, just spray through the bottom hole?
Best regards,
Minassie
Old 07-14-2014, 06:18 PM
RJ237's Avatar
It's been a while, but I believe I had to scrape the buildup out, then clean with acetone or other solvent. Hopefully, another member will come in with a suggestion.
Old 07-14-2014, 06:56 PM
PeterStrandberg's Avatar
Ive used oven cleaner for the diesel egr. It's made to dissolve coal soot and did just that. Read warning label though
bamforp
08-14-2024 05:36 PM
1100me
07-24-2023 06:10 PM
Kevin Burnaby
06-28-2020 08:04 AM
Boeingtravel95
09-14-2015 05:01 PM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: XJ6 - EGR valve
