XJ6 new Pistons and other engine Parts wanted
Hello Gentlemans
Iīm preparing to overhaul my AJ6 (straight six) Engine and Iīm looking for some new engine parts but I couldnīt find any.
Can anyone suggest where I could find those parts ?
Thanks,
Frank
- 6 pistons and piston rings, next size from normal (standard 91mm)
- set of main bearings (standard)
- set of connecting rod bearing (standard)
- set of Thrust Washer
- oil pump and filter
- crankshaft front and rear oil seal
- all chains
- all chain guides
Thanks,
Frank
- all chains
- all chain guides
I suggest some of teh sponsors on this site, like XNG Barratt, etc.
Not sure if things have changed since I was with Jaguar, but back then AJ16 pistons were NOT sold seperately. They were matched to the block, and that was a PITA, but failures of that engine are rare, so maybe not so silly.
Rings, bearings, seals, chains, dampers/guides etc, no problems.
THERE YA GO, corrected myself.
Piston assemblies are available, in STD (Standard) and 0.002" oversize. Thats it, as that block is not able to be machined in the bores.
You will need to specify 3.2 or 4.0ltr.
Received 10,990 Likes
Yeah, I remember maybe 10 years ago trying to help a fellow main and con-rod bearings for an AJ16. No joy.
The conclusion we drew was that there simply was no demand for them....thus no supply. As time goes by a demand might develop....as sooner or later even the famously robust AJ16s will eventually start wearing out.
I also remember, from about the same time, a USA Jag vendor (Motorcars LTD, perhaps?) having a 20-30 low mileage AJ16s from wrecked cars on hand...and offering them at a silly-low price (like $300 each or some such) just to move 'em. There was simply no demand, thus they were stacking up in their storage yard.
Grant Francis (01-03-2018)
You will find all the info here:
https://www.xj40.com/viewtopic.php?f=9&t=5119
If its not there, then you can safely assume that probably no one else knows or the info wasn't shared anywhere else.
Can someone explain the crankshaft journal bearings ( item # 2 ) different numbers for me ? Are they oversize or hardness related ?
https://www.jaguarclassicparts.com/u...-3-2-4-0-litre
Uncle Fishbits
10-17-2017 07:54 PM
tsingtao35
08-25-2011 04:56 PM
wack61
07-05-2009 02:40 AM
