XJ6 Suspension Overhaul
Received 10,892 Likes
im in the process of making diy for the whole front suspension
new stabilizer links and bushing
all new wishbone (control arm) bushing (4x top and 2x lower , 2x lower )
new shocks
new lower shock bushing
new spring pan bolt
im reviving my 96 vanden plas should be the same for you
new stabilizer link top bolts
new bottom shock bolts
new top and bottom ball joints
new rack n pinion
new outer tie rod ends
new wheel bearings
new shocks
new spring pan bolt
new rack n pinion
new wheel bearings
If you have any clunks or knocks, then you're probably looking at suspension bushes. As you say that it just feels stiff or solid, then the shock absorbers/dampers may be shot. If they lose compression, they become ineffective and so the car just bounces on the coil springs. Alternatively, if they seize, then the ride will stiffen considerably.
You can jack up and support the car and place a trolley jack under the suspension carrier, jack it up and see how quickly or slowly the shock returns when you lower the jack. It should be a smooth consistent action, in keeping with the jack lowering.
If you do replace the shocks, remember that there are various options, with some leaning more towards a softer ride than others.
Plenty of info on here about rear suspension!!
As you can see lots of different approaches one could take. It would be more helpful if you could describe the symptoms that you feel and/or hear.
Do you hear thumping/banging noises when going over bumps?
Does it happen while driving straight or only on curves?
Do you feel any vibration or buzzing though your steering wheel or the car seat?
Otherwise, as Doug suggested, a visual inspection should be carried out first. The rubber used in most of the suspension bushes/mounts will perish over time but is easy to spot if you get the car up in the air and use a pry bar to move various parts of the suspension.
If you are not hearing/feeling any knocks when going over bumps, my first thoughts would be to check the shocks.
