xj6 trunk won't open
Old 04-18-2008, 01:06 PM
Default RE: xj6 trunk won't open
Almost the same thing happened to my '98 XJ8 about a month ago. Neither the dash button or keyless entry fob would open the trunk, although I could hear the acctuator working. I'm not sure how your key works on the '95 XJ6 however, on my XJ8 the key doesn't turn at all, it's simply inserted intoa slot on thetruckwhich mechanically pushes the latching mechanism open. Of course my first few attemps also failed, and then I started pushing gently down on the truck a few times with the key inserted in the slot - and it worked! Come to find out,when our son put his bookbag in the trunk that morning,one of the shoulder straps became lodged in the latching mechanism. We we're so glad that I could get into the truck because our mechanic was talking about removing the license plate assembly and cutting a hole to expose the trunklatch. Best of luck
Ron
Tucson, AZ.
Old 04-19-2008, 09:08 AM
you can wiggle the key and spray rust penetrante in the whole.. if not PM me.
Old 10-01-2013, 01:32 PM
Rhett's Avatar
Just got our "new" '95 X300 and this morning, the boot lid won't open either from the button on the outside, the switch on the inside or with the key. It's not jammed, it's not getting power.
My mechanic said he thinks the wires from the body into the boot are damaged and that an hour or two of his time will resolve it. I like and trust him but if I can cut down on that cost by doing it myself, that would be good.
So: Can anyone tell me how I can get the boot lid open without having to drill or cut into the body?
Thanks in advance,
Rhett
Old 10-01-2013, 09:53 PM
dennish's Avatar
I have had 2 different issues re trunk opening on my 95 Sovereign.
1. broken wire on hinge,
2. failed solenoid actuator
luckily with both the key still worked.
Dennis
Old 02-15-2019, 06:24 PM
Benj628's Avatar
Default Update!
To anyone who comes across this in the future- if you are having this same issue, it can be manually opened with the key if you spray lubricant into the keyhole and work it back and forth until it moves freely.
Is is that still does not work you can remove the license plate, shine a flashlight into one of the holes where the license plates attaches (you may have to pop out one of the plastic license plate anchors) and look into the other hole and guide your screwdriver into the mechanism. This will take some trial-and-error but you will eventually get it!
The following 2 users liked this post by Benj628:
fatelvis (03-08-2019), Steve M (02-16-2019)
rusty37
04-05-2020 07:40 PM
dsnyder586
04-04-2019 02:38 PM
martybmw
04-02-2016 04:55 AM
XJsc-guy
11-23-2015 01:56 PM
Doovoe
XJ40 ( XJ81 )
09-06-2015 10:54 AM
Quick Reply: xj6 trunk won't open
