Xjr 1995 v6 hood ornament
Wow, a V6 XJR! That's very rare.
Joking aside, unless you have a swapped engine, it's a straight six you have under the hood/bonnet. Have you checked the pedestrian safety regulations about leapers? I've read that they're MOT failures for your car if they weren't equipped with them from the factory, though I can't confirm.
Don B (09-08-2015)
Not worried About mot mate do u have advice about fitting it
"Search" is your friend, suggest starting there as a lot has been written about the "leaper":
Jaguar Forums - Jaguar Enthusiasts Forum - Search Results X300
Jaguar Forums - Jaguar Enthusiasts Forum - Search Results X308
....may not have everything you are looking for, but a lot of info none-the-less.
Good luck![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Good luck
Don B (09-08-2015)
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
Hi
You should check this TSB that shows how to attach the Leaping Jag Ornament to the hood/bonnet
Here is the link
http://www.jagrepair.com/images/TSB/...Installing.pdf
Let me know if this is any help to you
Here is the link
al_roethlisberger (09-15-2015)
adam699
09-12-2015 05:32 PM
