XJR ignition timing and Coil spec
Hi
I tried to search for the information (forum and documentation I have) but with no luck
1) what is the basic (idle) ignition advance of the AJ16SC engine (or NA)
x degrees BTDC
I do not have the car available now so I cannot check with timing light
2) what are the specs for the Coils
]electrical like resistance (primary, secondary), dwell etc
mechanical; dimensions length (total, rubber boot) diameter of rubberboot
thanks in advance
Antti
x degrees BTDC
thanks in advance
Antti
