XJR no obdii Communication Failed smog
I picked up a 96 Xjr on eBay from Florida.
She's running great only 90k
Took it in to smog it today and everything passed except for being able to communicate with the computer.
I noticed I can't use my elm wifi obd reader to see values.says it can't connect.
I have a vcm with Ids on the way but if this doesn't work I doubt that will work too.
Any ideas?
One would think of its not communicating that the engine and everything else wouldn't run.
I'm super bummed about this. As it passed everything to perfect.
Any ideas?
There's a fuse for the OBDII port in the boot fuse box....sorry, can't remember which one, but do remember it is in the boot box. Anyway...if your elm adapter lights up when you plug it in, that's probably not your problem...but may be worth a check. 15A I *think* but could easily be wrong...
Hmmm... in that case... have you successfully connected your elm to any other cars' obdii?
I've had elm's that won't connect to the phone, some that won't connect to the ecm....think I had 1 that would connect to one of the s-types and nothing else....
It's a crapshoot with the $10 Chinese clones.
"torn everything apart" ? Have you had a good look at the OBD connector pins? How about testing ("ohming out"; I hate that term!) the ODB to ECU wiring? Any water on the ECU connector pins? And you can get a fleabay ecu for less than $200. That might not fix the problem, but it will go a long way towards diagnosis by elimination!
yep checked the pins.
they are all ok.
I used a multi meter to check to see the pin which is number 7 that goes to the ECU it's an orange wire. and it was ok.
it's so dang odd. you can see it communicating with the ELM "light flashing but it doesn't recognize the OBD connection.
the car runs perfect.
they are all ok.
I took apart the inside of the ECU and there's a lot going on in there.
from what I can see everything is soldered on.
i'm curious to know where the proms are.
and the supercharged motor has a different compression ratio and fuel injectors I think.
I ordered two xjr Ecus on eBay tonight. I guess will see how that works out.
I do not have a module incfront of me, but as I recall, among the large "chips" are two with a label different from the others that are in sockets. You must be EXTREMELY careful removing and installing them and you really should use a puller tool as shown. Check with your older bit head friends.
Have a look at the pdfs in post #4 here: https://www.jaguarforums.com/forum/x...roblems-62255/
FS[Australia]: XJR 99 For Sale
Kascol
11-30-2015 09:34 PM
