XJR Revised Crank Sensor Brackets
Received 10,990 Likes
I think the best way to get a hold of him is the private message him on these forums and just be patient. I'm sure he gets a lot of messages from other forum members.
Here is the original thread for Andy's bracket and the latest news. You can send him email or a PM. His email is in the thread.
https://www.jaguarforums.com/forum/x...engines-66536/
Bottom line, he has ceased production, but he is keeping a list of interested folks, and I think that list is up to around 15-20 owners now. So for anyone interested, I'd suggest at least letting him know. Best case might be that if there is enough interest, it may be worth his while to make one last run.
Maybe we can even offer a slight premium over his original asking price as an incentive? That may be an option.
....I'm in the market for one too
Dear All,
Due to the continuing demand, I have decided to restart production of my revised crank sensor brackets for AJ16 engines. My wife will be processing any enquiries and orders for brackets on my behalf at her email address helenstodart@gmail.com . However, she will not be able to answer any technical question. For that I would refer you my original thread.
DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
There are couple of questions that I am regularly asked about these brackets, which I shall endeavour to answer below
1. It is not necessary to use a higher octane fuel than 95RON (approx. 90 pump octane / 90 anti-knock index (AKI))
2. the bracket will also fit AJ6 engines fitted to XJ40 after VIN 667829 and XJS vehicles after VIN 179737
Thank you to everyone for your continued interest in these brackets.
The following 8 users liked this post by XJRengineer:
al_roethlisberger (05-30-2014),
BigBossRadio (05-30-2014),
Chattanooga_XJR (05-30-2014),
Don B (05-29-2014),
littlelic69 (05-30-2014),
and 3 others liked this post.
The following 2 users liked this post by mgb4tim:
XJRengineer (06-01-2014)
I would interested to know what air intake you would recommend as well. I know you can drop in a K&N filter (Part #33-2003) into the stock intake.
Is it worth it to go to Mina Gallery for a aftermarket intake or to try and fabricate one on your own?
If anyone has had success fabricating one on their own can and feels it is worht doing can you let us know what parts you used and what filter part number (or filter dimensions) you used?
I have tried every imaginable intake combination out there, and I have come to the conclusion that the best bet is to replace the original filter with a k&n or just using a cone filter, instead of the air box , with a heat shield is your best option. I personally use the cone filter, but during the summer months I go back to the stock air box with a k&n filter. The only thing of any value would be the heat shield because you can buy a cone filter anywhere.
jaguarcraver (06-02-2014)
A heat shield is easy enough to fab. from aluminium sheet. I posted some descriptions and pics of the set-up I put together several months ago. I run the cone filter right through our hot summer months with the shield in place, and no problems. Piecing an intake system together is also pretty easy, and way cheaper than buying from Mina Gallery. Having said that, the Mina kit includes a SS pipe with a welded connection for the hose that's attached to the bottom of the stock air box on the XJR (not applicable on N/A engines, so the connection has to be blanked off).
If it's of any help, see posts #223 & 224 at:
On my car, I've found this mod. along with the Andy bracket has made a big difference to performance and a minor benefit to fuel economy.
All, a reminder; the following is the correct thread to keep up on news and availability:
aholbro1 (11-21-2015)
RoyLittle0
05-25-2023 02:38 AM
joesoap
09-10-2015 01:09 AM
