XJR springs on an XJ6?
Received 10,920 Likes
Of course they will. But i´m not sure you will be satisfied.
Pretty sure that Eibach has springs for your car and they will almost certainly make a different
The XJR has a pretty good body roll aswell.
Question: Som of these cars have a rear antirollbar have yours?? if no there should be an easy install
The XJR and Sport models have the rear bar and a larger front bar. I think this probably more significant than the springs
Doug is absolutely right. If you check the Jaguar Classic Parts website you can see that the XJR has different springs, dampers, anti-roll bar and even anti-roll bar bushes to other models. The parts are phisically interchangeable. There is no reason that you couldn't make an XJR ride and handle like and XJR.
If you want your car to handle even better than an std XJR then you should fit my rose-jointed (heim-jointed) front anti-roll bar drop links.
rusty37
04-05-2020 07:40 PM
Tar
09-06-2015 11:24 AM
