XJR stopped, transmission light is on, won't start
Old 05-11-2014, 04:42 PM
Urchins's Avatar
Default XJR stopped, transmission light is on, won't start
Hello, I have an issue with my 1995 XJR.
While driving my engine suddenly stopped and the transmission light appeared. I tried to start it again but it only cranks. Then I tried to restart the computer by removing the battery terminals and after putting them back again the car stopped cranks as well. I tried to press the crash switch but it didn't help. The fuel pump is working fine as I can hear it running, it has fuel, the battery is OK. I, also, move the gearshift on Neutral and tried to start the engine - nothing again.
When I turn the ignition on, all the lamps turns on for the check and after turning off, the transmission light appears again. After trying to run the engine the SRS Air Bag light appears, but nothing else happens.
I will appreciate any suggestions and help related to the problem.
Thanks in advance.
Old 05-11-2014, 08:47 PM
jeremiahjaguar's Avatar
I would first check the ecm relay because its the easiest, but you should second check the crank position sensor. had the same problem with my 95 xjr6.
Urchins (05-12-2014)
Old 05-12-2014, 01:20 AM
Urchins's Avatar
Thank you Jeremiahjaguar. I'll try the relay today. It should be situated behind the right headlight, shouldn't it?
Old 05-13-2014, 12:56 AM
ecm relay is behind the passenger side headlight. you can find all the info you need on this site, just look up ecm relay and crank position sensor.
Urchins (05-13-2014)
Old 05-13-2014, 06:25 AM
Urchins's Avatar
I have checked them and it didn't help.
Is it possible the problem to be caused by a bad throttle position sensor?
Old 05-13-2014, 08:44 AM
Urchins's Avatar
I have realized that the check engine light do not stay after the check...
Old 05-13-2014, 10:55 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
The common no start mantra "What does the tach do while cranking"!
It is highly unlikely your problemis a TPS.
Old 05-19-2014, 07:19 AM
Urchins's Avatar
Excuse me for the delay answer, I was on a business trip.
I don't remember what the rpm did when the car was still cranking...
Now it do not move when the car is on ignition.
Old 05-19-2014, 12:43 PM
sparkenzap's Avatar
Hmmh. I guess you need to get it to crank again! Are you sure the battery is not run down due to cranking without starting? Maybe clean the battery terminal, and that will also do a "hard boot".
Old 05-20-2014, 03:47 AM
Urchins's Avatar
Yes, I am sure for the battery. By the way, I didn't have the chance to exhaust the battery, because after two attempts to start the car, I restart the computer by removing the battery terminals, after which it stopped cranking.
Hope I'll start the car soon, because this was not in my plan. I have just bought a refreshing kit for the supercharger ...
sparkenzap (05-20-2014)
Old 05-20-2014, 08:17 AM
sparkenzap's Avatar
If you have another key, try that. (security transponder).
BrentGardner
28
04-26-2024 03:08 AM
1964Daimler
09-02-2015 11:41 PM
Rusty1952
09-01-2015 05:45 AM
Spikepaga
08-30-2015 12:59 PM
Drew2006
08-28-2015 04:22 PM
Quick Reply: XJR stopped, transmission light is on, won't start
