XJR trans solenoids - can use generic 4L80E ones?
Limp mode comes and goes - getting codes P0753 and P0758, with a P1775 tossed in. Replaced the trans mount spring and foam isolator. New spring seemed *slightly* stouter (should have measured it vs OE...) Harness and pins *look* great, TCM unit and plug too. New Dex 4 fill up. Still regularly getting limp mode.
Figured I'd actually replace the solenoid called out in the codes. Question is will standard 4L80E A/B solenoids fit?
https://www.amazon.com/gp/aw/d/B009GNAZUM
lso - looks like a Delco TF249 filter might fit. Can anyone confirm?
https://www.amazon.com/gp/aw/d/B000C9OZMI
Many thanks.
Many thanks.
Received 10,990 Likes
Yes on the solenoids... and filter, too
Welcome to Jag-lovers - Members Photo Viewing Page
While you're all drippy with ATF I'd consider replacing both speed sensors as well. Like the solenoids they're standard 4L80E pieces and often give trouble
