xjr6 auto gear box
Guest
Posts: n/a
Received 2,195 Likes
Guest
Posts: n/a
RE: xjr6 auto gear box
A common cause of this fault in the XJR6 is a worn rear tranny mount which damages the too-short wiring harness to the TCM by pulling the wires out of the pins, giving all kinds of strange operational problems. Do a pin out test of the harness to be sure, it is expensive to replace and a used one is probably not a good investment. The repair is a new harness and mount.
Guest
Posts: n/a
Ican't get the fault codes read untill next week, i have tried a snap-on ethos and autodiognos both won't read the gear box. The only codesI got were mass air flow. But todayI put her on the ramp and found the front prop shaft drive flange loose, so I
tightend it up andcar drives well, the only timeI can get the fault to occur now is if i hit a bad bump in the road. so gear box harness will be checked tomorrow. Thanks for all the help guys
Guest
Posts: n/a
