XJR6 Engine ECU Successfully Remapped
#61
#63
#64
XJRengineer, I've briefly read through all of this thread, so apologies if this has already been covered.
I'm looking at putting an AJR6 engine into a completely different car.
I have previously done this but was fortunate to have an ECU supplied by Jaguar with no security codes on it.
Are you able to modify an ECU to remove all the security from it, so it can be used in a different vehicle?
#65
I was once contacted by someone involved in the build of the car that you menioned. As you write, you were very fortunate to have a non-production ECU for that car which enabled it to run without the std X300 security ECU. I can programme ECUs to run XJR6 engines in conjunction with manual transmissions, without the security ECU. I don't know how such an ECU would work in conjunction with an automatic transmission, if this is what you intend to use in.
I may have a solution if your intended vehicle will use an automatic transmisison, but I'll await your confirmation of the transmission specification.
#66
Here's the bay of the one we previously built:
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/42301-xjr6-engine-ecu-successfully-remapped-_igp0513_zps72412b00.jpg?dateline=1368171973)
We have also built one with an non supercharged X300 engine, and managed to get this one running by sourcing a very late XJS ecu with no security on it:
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/42302-xjr6-engine-ecu-successfully-remapped-imgp2246_zps9c909d81.jpg?dateline=1368171973)
Both of these were Automatic
I would like to build a manual XJR6 powered one now, as I have a manual XJS gearbox I should be able to use.
But ideally I would like to find a solution for auto boxes as well, as Auto's in our cars seem to be more popular, and would love to be able to use these engines.
doc (05-11-2013)
#67
crazy cats!
Here in NZ Greg Beacham puts rebuilt V8 XJR mechanicals into Mark II saloons and series III E-types...
Beacham Jaguar - Independant Dealer & Classic Restoration & Custom Car Experts
#68
#69
#70
Schmirtz,
If you are just looking for a bit more performance, then fitting one of my brckets is more cost effective, than remapping the ECU. That is more appropriate if the engine has undergone a major upgrade (more than 10% increase in airflow).
I've spent the last 25 years working as a professional engineer in the automotive industry. That experience is very helpful when undertaking a project such as my Eaton M112 upgrade.
#71
Hello there,
Please would anyone know what kind of cable will be compatible with a Jaguar 2.7D S Type 2006 Model for using remapping software.
The KWP, MPPS and Galletto don't seem to work...
Finally got my head round the remap successfully on other cars but cant do my Jag as can't find a compatible Cable.
#72
crazy cats!
Al have seen his work before only one word to describe it Wicked!
#74
#75
Hi,
I currently have a 95 XJR, which seems to have faulty ECU: random misfires, undeven idle and restricted performance. Electrician said the current is randomly jumping for MAF and 02 sensors and code P1621, no other codes.
I have trouble finding replacement ECU LNA1410TB/511, but I think I have in garage somewhere an ecu from my previous jag: 95 XJ6.
Is it possible to remap the ecu from xj6 so it becomes correct one for the xjr as a replacement?
#76
Yes. You can take the EPROMs out of one ECU and put them in the other ECU, if you are comfortable taking an ECU apart. I would recommend using an anti-static mat. You will also need to perform a throttle adaption and potentially a lambda sensor orientation, which both require service diagnostic equipment.
#77
Thanks for an answer, hopefully this will solve my one year quest...
#78
#79
As I warned you, a lambda sensor orientation might be required. There was a 50/50 chance of it being necessary. The fact that the engine initially runs until the it starts to warm up, before idling really badly, suggest that this is the case. It is important that the ECU is configured to know which signals come from the lambda sensors in the gas from cyl 1-3 and which signals come from lambda sensors in the gas from cyl 4-6. Your replacement ECU has probably come from a car in which these connections are the other way round. You need to get to the two pairs (assuming your car is North American spec) of lambda sensors; one pair is near where inlet runner number 6 meets the cyl head and the other pair are on the RH longitudinal tube in the engine bay, near the half engine speed sensor. Swap these pairs of connections around and the engine should run much better as it starts to warm up. When the sensors are connected the wrong way round 3 cylinders will run 25% too rich and the other 3 cyls run 25% too lean. This is a simple mechanical alternative to running a lambda sensor orientation test, but does not calibrate the ECU to the specific electrical characteristics of the sensors. I would still recommend running a lambda sensor orientation test, as discussed earlier in this thread.
If when your engine is running more smoothly, it does not idle at the correct speed when fully warm, then you will need to perform a throttle adaption. Also discussed earlier.
#80
Will try to find who can make the reorientation. The major problem is that even the dealer in my country refuses to take the car in: too old for them.. :/ Therefore I have to find things out myself. Before swapping the ecu with and EPROMs I had not so bad, but in essence similar problem of misfire when car warmed up, can it be this was also cause due to not performed O2 orientation (they were changed to new ones)?
