XJR6, making it roadworthy, compression
Update: replaced the lambdas with FAE correct ones and it works. New problem, the car drove almost perfectly until there was rain. Checked ecu: about a teaspoon of water in the black contactor and the pin for the injectors broke or was broken.. So now I have two things to figure out:
1. Where to find ecu side black connector to be soldered on
2. How to stop water ingress
Any takers?![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thank you all for your help so far.
Any takers?
AMP ecoseal 36 pin
https://fi.farnell.com/amp-te-connec...8?ost=344108-1 but crosscheck..
Partco can order them from Farnell.
wred_e (08-09-2021)
You should also check the site of Jim Butterworth especiallyJaguar XJ6; Jaguar X300; Engine Control Unit; ECU
Cafcpete (08-10-2021)
Jag_ged
05-11-2014 05:44 AM
JaguarJae
03-25-2014 08:53 PM
