XJR6, making it roadworthy, compression
Old 08-08-2021 | 02:45 PM
AnttiM's Avatar
Originally Posted by wred_e
Update: replaced the lambdas with FAE correct ones and it works. New problem, the car drove almost perfectly until there was rain. Checked ecu: about a teaspoon of water in the black contactor and the pin for the injectors broke or was broken.. So now I have two things to figure out:
1. Where to find ecu side black connector to be soldered on
2. How to stop water ingress
Any takers?
Thank you all for your help so far.
If I recall correct it is
AMP ecoseal 36 pin
https://fi.farnell.com/amp-te-connec...8?ost=344108-1 but crosscheck..
Partco can order them from Farnell.
wred_e (08-09-2021)
Old 08-10-2021 | 01:38 AM
AnttiM's Avatar
You should also check the site of Jim Butterworth especiallyJaguar XJ6; Jaguar X300; Engine Control Unit; ECU
Cafcpete (08-10-2021)
ablack
02-25-2019 10:13 PM
rexrich007
12-20-2014 03:07 PM
Jag_ged
05-11-2014 06:44 AM
JaguarJae
03-25-2014 09:53 PM
3000
11-07-2013 09:26 PM
Quick Reply: XJR6, making it roadworthy, compression
