XJR6 Muffler suggestions
XJR owners. I made a mistake with exhaust system a few weeks ago.
The GOOD - Had the primary down pipe cats replaced with two new Magnaflow spun stainless metallic core. The secondary underfloor cat had been removed by previous owner and a X-Pipe installed. While the shop was replacing the cats I also had them swap the four O2 sensors with new OEM sensors purchased from Rockauto. Stinky exhaust solved.
The BAD - I had the shop remove the 1st set of mufflers, the original Jag ones in front of the IRS because they had an annoying midrange buzzy sound coming from them. The previous owner had replaced the rear mufflers with Edlebrock TruFlo mufflers. The car is now way too loud and sounds terrible, very "ricey" from 2000 - 4000 RPM.
I am thinking of having the exhaust shop weld in two glass pack mufflers where the 1st set of OEM mufflers were removed and replacing the Edlebrock rear mufflers with another pair of glass packs. I want a free flowing exhaust with a nice growl, not too loud but want to still be noticeable when I put my foot down.
Does this sound like a good solution? Has anyone had success with similar set-up?
I left the original resonators on my car and replaced the mufflers with Thrush turbo mufflers. The Thrush mufflers are cheap, but they have a nice sound when paired with the original resonators. I may eventually switch them out for magnaflows. I feel that the stock resonators do a good job of keeping the noise levels down in the cabin and paired with just about any higher flow muffler have a nice sound. I'm too old to be driving around without resonators on a car.
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have four quick questions:
1) What model# down-pipe catalysts did you use?
2) Did the four stock O2 sensors that install above and below the down-pipe bolt right in without modification?
3) When the previous owner removed the under-floor catalysts, did they retain the O2 sensor that is installed after the under-floor catalysts?
4) Do you get any OBD codes or check engine light?
2) Yes they threaded right into the original bungs, NTK 25018.
3) They must have, when I bought car the second set of sensors were directly downstream of the down-pipe cats.
4) None, well not until I unplugged my EGR Valve
There isn't one after the underfloor cats, only the downpipe cats. You can remove the underfloor cats and the ECU will never know.
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Ah gotcha, you are correct
https://www.jaguarforums.com/forum/x...ntages-152568/
So John, good news that the new catalysts worked fine, O2 sensors went right in and didn't trip any codes.
You think these Magnaflow catalysts are higher flow efficiency than the OEM?
JagZilla
02-15-2017 09:18 PM
