XJR6 radiator fan runs continuously.
Which engine type do you have? AJ16 or V12 ?
Thanks for that Andrew, but unfortunately this unit is not just a relay it is some sort of module/relay with many pins.
Hi RJ237, it is 1995 MY, but late 1994 build. Anyway, are you saying that it is correct for the fan to come on with the key even when engine is completely cold? If that is so then yippee! I don't have a dreaded electrical problem at all. It only has one fan on the right hand side of the rad. The left hand side just has some rubber flaps to let air through with increasing road speed.
Here is a link to XJ300 TSB's you may find helpful
JagRepair.com - Jaguar Repair Information Resource
Just curious
Hi BigBoss, My car has the straight six 4litre with supercharger. On the right side of the rad is an electric fan; the left side is covered with rubber flaps that obviously will open as road speed increases to allow more air to pass through the core. Is this arrangement unique, or just for British market I wonder?
BigBossRadio (09-16-2015)
