XK8R/XJR/XJ8 Brembo Brake Kit
Hi all,
I'm upgrading my X300 wheels to 18" x 8.5" Milans soon. Saw this Brembo brake kit on an old catalogue and was wondering if its a bolt on fit or do I have to use adapters etc? Any thoughts please?
http://www.jag-lovers.org/brochures/...ons99_15_l.jpg
Best,
Kopi
Best,
Kopi
Jaguar XK8 - Video Dailymotion
The calipers are the same with XK8s but the disk offset of the front is different, so I think you won't be able to fit the front calipers and discs without modification.
Thanks Japthug. Do you think I would have to use some spacers then? Is that advisable?
Firecrow, I did actually search the forums but did not find a conclusive thread. Most are "should" and "could" and "perhaps" ... but I did not come across anyone who actually bolted it on. Would appreciate a thread link from you if you've come across it recently. Maybe i'm not searching it right.
https://www.jaguarforums.com/forum/x...xchange-18001/
Found this ... seems like it would clear my Milans. But since it came from a X308 thread I'm still not so sure.
I'm about to plonk down a significant sum for the brake so I have to be doubly sure it'll fit.
Sorry but I cant tell if you can fit brembo discs with spacers.
But from the dimension of the discs I don't think you can, for the thickness difference is 11mm from the top of the hat.
In addition, even the normal R of X308 has a different hubs from the ones of the NA models in order to clear the larger discs (NA: 305mm dia, normal XJR:325mm dia, Brembo:355mm dia) so I think you will need a bracket anyway.
I found that XK8 is fitted 325mm rotor from 1999 and that might be the reason they fit the brembo straight forward in the movie.
scooternva
20
09-27-2023 11:25 AM
metalmarty
09-11-2015 07:05 AM
1964Daimler
09-09-2015 11:28 AM
1964Daimler
09-09-2015 11:20 AM
