$2 Cup Holder Fix Procedure with Pics
I had a hard time finding a good guide and pictures for fixing the cup holder so I decided to make my own.
Tools and materials needed:
Grinder or file
Vise Grips or pliers
Dial or Digital Caliper
Drill with drill bits- I used a 1/16" bit (.060) and 17/64"(.066)
Screw Eyes- I got "National" brand size 214
1) The screw eyes i picked out are slightly smaller than the diameter of the cup holder hinges. The reason is that i wanted a nice and snug fit with minimal slop. You need to drill them out with the 17/64 drill bit. This also gives you more contact area against the plastic.
2) Take measurements of the hinge height location, preferably with a caliper.
3) Grind the old hinges down until they are flush with the base.
3) If you got the same screw eyes as me, you will need the 1/16 bit to drill pilot holes. Otherwise use a bit that is slightly smaller than the thread. Drill the pilot holes at the intersection where the grinding marks meet the the unscathed plastic and .175" from the bottom.
4) Screw in one of the screw eyes until it is between .460" to .500" high from the top of the screw eye to the base. I set mine at .460"
5) Screw in the second one to the same height, but then back off slightly so it is at a 45 degree angle to the first screw.
6) Insert the side with the 90 degree screw eye first. Then press in the second side. Once it's in, use pliers to rotate the 45 degree screw eye back to 90% in the clockwise direction.
7) You may need to do some final adjustments before you put it back together
Once it's done, it feels very strong. I probably don't need to do this, but for peace of mind, I will also add some epoxy to the exposed threads for extra strength.
Grinder or file
The following 8 users liked this post by Murat:
adriaxj8 (03-04-2012),
Dan R (03-04-2012),
holybananas (03-03-2012),
ixj8it (03-03-2012),
jimlombardi (03-03-2012),
and 3 others liked this post.
The process was explained in a posting by someone who does propeller repairs on ultra light aircraft.
apply the cyanoacrylate adhesive to the joint, sprinkle baking soda on area, wait a few seconds, blow/brush off excess, repeat as required to build up area.
It worked very well when used to repair an alignment tab on a tail lamp housing. The baking soda acts as a catalyst and filler in the presence of cyanoacrylate.
aholbro1
08-05-2021 05:02 AM
