“Brake Fluid Low” false light
Hello everyone,
I ran across a thread addressing this a while back, but can’t for the life of me find it now. I’m getting an intermittent BRAKE FLUID LOW along with BRAKE warning lights. I can’t see a pattern, it just comes and goes, but does seem more frequent now and lasts longer.
As per that thread I found, I tried jumping the sensor plug with a paper clip and that didn’t work. I’ve jiggled the plug while in and that doesn’t seem to affect it either.
Any suggestions here? Do I need to bleed the fluid and replace it, replace the reservoir, etc…?
That bright red light is driving me nuts. Lol.
Many thanks in advance to all.
Could also be the ABS module. My dad's XJ8 was constantly giving false brake fluid low warnings even with a new sensor and no wire damage and a clean connector. Didn't stop until I replaced the module. Start with the wires and sensor first but check out the ABS module too, especially if your also getting traction/stability fail warning.
3timejag (03-19-2022)
