“Trunk Open”...but not
Old 02-29-2020 | 09:17 PM
3timejag's Avatar
Default “Trunk Open”...but not
I recently acquired a 1998 XJ8 Vanden Plas. There is a separate key for the trunk only, so I’m assuming there have been issues previously with the lock. The Trunk Open light stays on and I would like to know where to start trouble shooting before I delve into pulling the trunk lock area apart.
Many thanks to All!....Best forum and members ever, no doubt.
Old 03-01-2020 | 09:47 AM
Highhorse's Avatar
Yeah, sounds like its been replaced and someone forgot to connect something or didn't align it. For a matching key setup, you may want to contact Sone and see if he can help... https://www.jaguarforums.com/forum/market/227433
Don B (03-01-2020)
Old 03-01-2020 | 10:59 AM
3timejag's Avatar
Thank you!
Old 03-01-2020 | 01:02 PM
Jhartz's Avatar
I had the same issue in my first 2001. Check the wiring that runs along the right hand side hinge in the boot. Mine was a shorted wire from the lock to the computer at the hinge.
The following 2 users liked this post by Jhartz:
3timejag (03-01-2020), Don B (03-01-2020)
Old 03-01-2020 | 02:15 PM
3timejag's Avatar
I will, thanks Jim, you’re always a great help.
Old 03-07-2020 | 10:53 PM
3timejag's Avatar
Test
Old 03-07-2020 | 11:01 PM
3timejag's Avatar
Okay, I posted that “test” because I tried a lengthy post here and it wouldn’t take, and I lost the type....
altight, I checked for frayed or broken wires in the trunk, at the hinge, and found nothing. While in there, I popped open the trunk liner and saw a little greenish connector that ran to the open button. I disconnected it, and that made the “trunk open” light go away....but it also caused my alarm to go off after about 3-4 minutes after I parked the car. Hmmmm. Okay, we’ll I reconnected it thinking the alarm issue would go away, but now the alarm goes off only if I lock the car. Leave it unlocked, and no alarm. I am starting to think it could be the security locking module?? Does that sound possible? All of my brake lights are fine and I say that because I’ve had brake light issues in the past on my other XJ8’s and the SLM was the issue.
Can a faulty SLM cause trunk light/alarm/lock the car issues as described here?
Many thanks in advance, I’m veery perplexed...
Old 03-07-2020 | 11:03 PM
3timejag's Avatar
Oh, and I can’t program my key fob, tried my known good one and no go...SLM?
Old 03-07-2020 | 11:38 PM
Highhorse's Avatar
Try a hard reset.
Old 03-08-2020 | 12:01 AM
3timejag's Avatar
I did before this alarm thing started, but I’ll try that again. So do you think the SLM could have anything to do with there issues as well?
Old 03-08-2020 | 08:02 AM
Highhorse's Avatar
Its possible...this is what sucks with 20 yr old electronics.
Old 03-08-2020 | 08:37 AM
3timejag's Avatar
I heard THAT! 😂
Old 03-08-2020 | 10:38 AM
motorcarman's Avatar
You need to look at the switch in the latch assy. They are the same for the X300 and the X308.
Boot lid open warning microswitch LNC6242AC
3timejag (03-08-2020)
Old 03-08-2020 | 04:17 PM
3timejag's Avatar
I have purchased the micro switch and an actuator. Hopefully this will solve my problem(s).
Many thanks to everyone!
Old 03-15-2020 | 06:40 PM
3timejag's Avatar
update...I bought a micro switch and an actuator and installed them myself. Everything working now (it was the actuator), but now I can not for the life of me figure out where that micro switch should be seated! I have it hooked up, but don’t know where to secure it....can you help? Thank you for the suggestions as well!
Old 03-15-2020 | 09:01 PM
M. Stojanovic's Avatar
You should Google, a lot of info and pics can be found. This is what I just got searching for "Jaguar X308 trunk lock":
3timejag (03-15-2020)
Old 03-15-2020 | 09:05 PM
Highhorse's Avatar
Surprisingly there are limited details on this....
(MS just got ahead of me on this)
Old 03-15-2020 | 09:15 PM
3timejag's Avatar
I was Googling “1998 xj8 micro switch location”, and similar terminology...no results...but then again I had forgotten it went on the latch.
Thank you!
Old 03-15-2020 | 09:18 PM
3timejag's Avatar
Yeah, I didn’t see anything either and of course had I remembered it went ON the latch, well, I wouldn’t have needed this information/picture(s).
feeling kinda dumb right now😂.
Thank you so much!
Old 03-15-2020 | 09:24 PM
3timejag's Avatar
Bonomassa one of my favorite artists, this is killer! This guys my favorite...
Quick Reply: “Trunk Open”...but not
