00 Jaguar Vanden Plas XJ8. Petal Brake Switch. Good or Bad
Recently my Jaguar Brake lights stopped working all 3. Reading this for him I did not think it was the security controller given the fact that the single light in the rear window was not coming on at all also
With that said I removed the brake Switch (see photos) to test it with a volt meter.
Inside the plug plug there is 4 connectors. The only time I get a completed circuit when the switch is depressed is when touching the middle two terminals ie 2 and 3. Any other combination I do not get a complete circuit. I think the switch is bad but I am not sure.
Can anyone recommend the proper way to test this switch. Also can I jump the terminals on the female plug still in the car to test the brake lights with this switch out? If so what terminals do I jump off
thank you for your help.
Dave
Dave
SOLVED - Verifying Brake Switch vs. SECURITY LOCKING MODULE UNIT (SLMU/SLCM)
To all - I have determined the issue with the Brake lights on my 2000 Jaguar Vanden Plas XJ8 - the issue is the Brake Petal Switch but I thought it would be helpful to others on how to know it is the switch vs. the Security Locking Module Unit also called SLCM
First of all if NONE of the brake lights work - the 2 tail lights and the single light in the rear window - it points to the brake switch at the petal. If you get the rear window light working but not the 2 tail lights it will point to the SLMU as the tail lights are on their own circuit vs the rear window light.
When checking the switch there is 4 terminals in the switch (see pic 3) check terminals 1 and 4 - this controls the brake lights - terminals 2 and 3 controls the cruise control (stoping it when you hit the brake)
Now if you want to see if it JUST your brake switch and not the SLMU (also called SLCM) controller in the back you can manually jump the plug that goes into the brake switch by running a wire from the 1st hole in the plug to the 4th hole in the plug (see pic 4 - last pic) - make sure you really, really push that wire into each hole - needs to be in there deep to make the connections. Once this is done, if your brake lights come on - all 3, then your controller is good and it is ONLY the switch you need to deal with. If you get only the rear window brake light coming on but not the 2 tail lights then you will have to look at replacing your controller also if both the switch and controller is having issues.
I hope all of this helps anyone in the future with a similar issue:
Dave Mc
Picture 1 - Brake Petal Switch from '00 Jaguar Vanden Plas XJ8
Picture 2 - Brake Petal Switch from '00 Jaguar Vanden Plas XJ8 - other side view
Picture 3 - Brake Petal Switch from '00 Jaguar Vanden Plas XJ8 - this view shows the plug on the switch itself with what the various terminals are responsible for controling
Picture 4 - Brake Petal Switch from '00 Jaguar Vanden Plas XJ8 - pic is of the plug that GOES INTO the brake petal switch and how to jump it to maually turn on your brake lights.
Dave Mc
Last edited by Djmcmann; 10-26-2018 at 09:59 AM. Reason: Brake Lights, Switch, SLMU Control, XJ8, Vanden Plas, SLCM
Jhartz (10-26-2018)
Good job doping it out correctly: when my brake lights went out (SLCM issue), the high brake lights worked (for a while I ran a parallel line to the rear left (rear rights worked). New SLCM worked for me. Another check would be to see if cruise control came on (or out on application of brake).
Just a VERY important side note - when I got the NEW switch - see the pictures I posted in this post. As I stated, Terminals 1 & 4 in the plug control the Brake Lights. When you test with an OHM meter these 2 terminals they are active UNLESS the switch is depressed. Once depressed the switch turns off - so for the brake lights, the switch is ON - OHM meter reads flow when not depressed and OFF when depressed OHM meter shows no flow. For terminals 2 & 3 the center 2 it is just the opposite for the cruise control. Hope this clarification helps.
WinterJag
05-13-2018 08:56 AM
Yellow series3
09-03-2017 11:55 PM
