'00 Vanden Plas - Rear Brakes - Grinding
While replacing my rear shocks and shock tower bushings, I went ahead and put in new brake pads and got the rotors turned so that basically everything would be done on the rear end.
However, since that time, I get alot of grinding from the rear brakes at low speeds and can hear it with the windows down. Seems about equal on each side. In my life, I have done more than my fair share of brake jobs but this is the first time I have seen this behavior.
Do you all think the need pads just need to "seat" in a bit or should I start pulling everything a part and inspect?
Thanks in advance for the help.
etachu
10-01-2017 12:24 PM
