01' Jaguar XJ8 Front Parking (side) Lamps Not Working
Old 02-08-2018, 04:48 PM
holybananas's Avatar
Default 01' Jaguar XJ8 Front Parking (side) Lamps Not Working
The front parking (side) lamps have never worked in my 2001 Jaguar XJ8. These are the small light bulb in the high beam assembly. I removed my lamps and noticed the connector was in pretty bad shape in one of them. I have a parts car with fully working headlight/high beam/front parking lamps, so I decided to remove the entire electrical connector (it's fitted in with a clip). So I took that off and put it in my current car and everything works as it should except the front parking (side) lamps. Is there a fuse I should be looking for? I've looked in my manuals and can't find anything. Any help would be appreciated. Thank you!
Old 02-08-2018, 05:58 PM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
No dedicated fuse found . Does the light stalk give it a ground in the other positions ? if not give the Red / Yellow wire a ground . Next step would be the Body Processor Module .
holybananas (02-08-2018)
Old 02-09-2018, 10:27 AM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
It is a common problem in the x308 and the x400. The lamp case is the ground and it causes excess heat (due to poor contact) the on the plug that distorts and melts it. There is a way to and an additional ground wire that can be found searching in the x400 forum.
Lady Penelope (02-09-2018)
Porterfamily
07-31-2017 05:39 PM
sanchez
04-01-2016 10:55 AM
savhomer
22
06-06-2013 06:11 PM
daboss085
03-17-2012 07:13 AM
Mark97XK8
09-10-2011 07:04 PM
Quick Reply: 01' Jaguar XJ8 Front Parking (side) Lamps Not Working
