01 XJ White Clear Coated?
Old 10-08-2013, 05:04 PM
Huntervision's Avatar
Default 01 XJ White Clear Coated?
If you can point me to where I might find this info, I'd appreciate it.
I have a 6" scratch from between the headlights up. I suspect it was a rock. Anyhow, I want it blended so as to preserve as much of the original finish as possible. A local shop agreed it could be spotted but said they would have to shoot the whole hood with clear since it is two-stage.
That may be true, but I'm not sure. I brought some touch up paint for my 06 white Subaru and the order was adjusted because it was clear coated; not so for the Jag which was ordered at the same time.
Thanks!
Old 10-08-2013, 05:29 PM
Stuart Beattie's Avatar
Hi Rick,
You obviously like your Jag and I'd be careful if I was your good self.
You did right sourcing info and I am sure you will get good advice shortly?
I am sure your paint would have been 2 stage, with a pearlescent clear laquer on top, so I think it will do the job, but I am speaking as
a novice in that department and I'd take your time over that if I were you, you want the right job done!
Good Luck, Stu
Poet
06-07-2019 07:54 PM
Poet
10-02-2015 09:00 AM
FabCat
09-26-2015 12:16 PM
reb1999
09-26-2015 08:41 AM
vacolorito
09-25-2015 09:29 AM
Quick Reply: 01 XJ White Clear Coated?
