01 XJR New Codes!
How exciting!
MIL came on this evening, around the beginning of a 120 mile round trip. Car ran great, never skipped a beat, figured it was probably my on again, off again left cat code that comes and goes since I bought the car 2 years ago. But nope, today I have P0171 and P0174!
Did some searching, lean on both cylinder banks, so its got to be a common bit on the intake side. I tried spritzing brake cleaner around the intake tube, full load and part load breathers and the throttle body, nothing. Removed the intake and cleaned the MAF, reassembled. Put a bright light inside the air intake tube, couldn't see any light coming through the bellows. I think I can hear what sounds like a vacuum leak around the part load breather, which I snapped and had to repair with some shirk wrap when I did the cam cover gaskets, so it might have sprung a leak there, but it could also be the belts hissing. Guess I'll remove the belts and see if the noise persists. Would the part load breather trip these codes? Usually it seems like its more of an air intake tube problem than not, but of course just because others have had that, it doesn't follow that I will.
Other ideas?
Other ideas?
How exciting!
Other ideas?
Other ideas?
V8 Str
27
07-19-2012 04:45 PM
