01 XJR not starting
01 XJR not starting
So, a few weeks ago my car while driving went into "limp" mode and was giving asc/trac error. Got it towed and took it to the mechanic and he said it was a bad battery which in turn fried my alternator. Got the two replaced and the car started right up. Drove home and then tried to start the car shortly after and it would not start...here's what I can say: it clicks when I turn the key...it does not crank. 10 days later I decided to try it again and bam it started. It drove fine then I turned it back off and bam same symptoms. It would not crank just clicked every time I tried to start it. I hooked up a code reader and just gave p1000 and from what I read that is not really an indicator of anything really. For the heck of it I also tried to jump start it but to no avail. I am really out of options and I hope to find someone on here that can point me in the right direction. Thank you all in advanced!!!
Found this thread...and from reading it..it sounds identical to my situation.
https://www.jaguarforums.com/forum/x...o-start-41857/
hunter34
19
09-14-2022 11:09 PM
