02 jag xj8 jack stand points
#282
#283
#284
Whoa, I think I see an original water pump with the plastic vanes. I suggest replacement of that or you'll be probably taken it off to do that sooner than later. You can get them for around $40-70.
As for the mating surface, I think I had an O-ring for that? But that was 6 yrs ago and I can't say. I can say I had to take mine back off because I did a dry install with the gasket and it leaked. So I removed it and used a lite coating of Permatex Indian Head Shellac to seal it.
#285
Hi HH.
Yes I know it's the older/original water pump ,but it wasnt leaking before , don't remember it having a O-ring and feels smooth.(bearing feels smooth )
I like to hear it run before I throw more parts at it and decide what I'm going to do with it...
I didn't use and sealant on it when I part it back together. I have some anaerobic gasket maker that should work...
#288
Thanks guys..
I know they break given the age and countless Heat cycles. It's easy enough to get off just need it to last a little while longer.
CK- I looked on at new water pumps online most don't show or list a O-ring just a metal gasket some do show an O-ring, same if I lookup just the gasket no O-ring
Looking Though everything I removed , haven't thrown anything away yet.
#291
This has been the most time consuming and expensive car jackng I've ever done...!
I looked through everything, I have every seal,gasket, o-ring,part that was removed just don't have one that fits the pump...
Going to check with a guy down the road he rebuilds old old tractors see if he has a O-ring that fits,If he doesn't have one that will work, I guess I'll be ordering a new one.
Do you guys have one that you recommend?
#292
Rock auto has some at decent prices.........
https://www.rockauto.com/en/moreinfo...40757&jsn=2168
https://www.rockauto.com/en/moreinfo...40757&jsn=2167
https://www.rockauto.com/en/moreinfo...40757&jsn=2169 (this one shows an o-ring)
https://www.rockauto.com/en/moreinfo...40757&jsn=2170
#293
There all pretty much the same anymore....I'd initially check on ones with some kind of warranty (that's what your really paying for). Most are Chinese Repop's.
A1 Cardone 55-23149 ..have limited lifetime...however that's defined.
Airtex AW4124 ..again limited lifetime and much cheaper...go to Amazon, can be gotten from $35-56 there. Note on one of those at Amazon, they have a list of other vehicles it fits. You may find a better price using those vehicles. Like 2002-05 Thunderbird.
Now, as far the the expense of this car jacking...this has turned into a Carjacking......wait until CK and I start with the suspension...
#294
Or the ABS module.................
Or the rear shock donuts...............
Or the motor mounts.........
Or..............
#295
Thanks HH,CK
So Full of encouraging news.
Excuse me while I go tie a rope to the rafters.
I did manage to get an O-ring that fits may try it..
Looks like no matter who,where I order a new pump from its going to take a week or so to get it, Amazon guarantees by May 7th. Ugh!
Thanks for the information on the pump.
#297
#300
Well That didn't work to well, I prayed to the gods and they laughed at me!
After cranking for a bit I put the fuel relay back and it started right up ran like it has a dead hole, checked all my connections , started it again let it run for a few and got 2 messages
ASC and TRAC NOT Available.Also the rpms stayed high 1200.
Then the car said Hey Now and blew a coolant line..... SMH Should of walk away when I had the chance! !! Tomorrow is another day I may try a sacrifice without Mint Sauce. .
The right side /hard plastic broke but it fit into the rubber hose .. ok for now.
