02 jag xj8 jack stand points
#321
Our neighbors have goats, and we have a adjoining gate and let them in to help at times (the goats, not the neighbors!), but they get picky about exactly what grass to eat (again, the goats, not the neighbors) and I end up mowing in the end anyway!
Highhorse (04-18-2020)
#322
Good morning Crazies.
About to play with this pita again..
Can you tell is these 2 line from the expansion tank is right or do they crisscross like I've seen on some diagrams? The way they are now is how it was originally.
or should they go on like this?
CK is busy cutting grass and I'm still getting snow! Poor CK...
I been tuning my grass cutters...
#323
#324
#325
#327
#328
I remember when I use to do that....lol
I'm down to 2 trouble codes knock sensor bank 1. ( passenger side) correct? And reduce performance.
it's got a knock like a coil isn't firing, my old innova 3100 or Autel MS 906 BT DO NOT Have the ability to read live data for spark/coils.on this car... Or I don't know how to use them.
no codes for a bad coil.
#329
A failed knock sensor will give you the reduced performance message.
How is the car running? Is it running smoothly, or do you detect a misfire or rough running at idle and/or lower rpms?
If the car seems to be running okay and you don't suspect a faulty coil or fuel injector etc, etc, I would suspect that you do need to replace the knock sensor. A failed knock sensor produces the restricted performance message and restricts the rpms to below 3,000, but the motor should run fine at idle/low rpms
#330
#331
Here is a prior forum thread that may help............
https://www.jaguarforums.com/forum/x...misfire-45754/
What misfire codes are you getting......if any?
#332
#334
#335
No it didn't like it... but it ran...
disconnected one coil at a time each made the car run worse.
I then metered out the knock sensors bank one sensor is shorted to ground both legs..
Do you know if a bad knock sensor will cause it to run rough /funky?
next I guess I can pull the plugs and take a peek.. ?
#337
#338
Assuming the 4 plugs on the driver's side are known to be okay, how about swapping them with the passenger side, hopefully the misfire will now be on the driver side, and you can start the car with the intake tubing and MAF sensor connected and disconnect each plug on the driver's side in turn?
#339
Plugs are new , So far drivers side are clean and dry... not coated with oil or fuel.gap is good also
Just put it back together. Coffee time...
From the meter reading im getting I got to think the knock sensor is gone bye byes.
I can't text without my glasses !! Grrrrr
#340
Ah, too late.......................I guess the problem is the knock sensor??????
Rock auto has them for $67 bucks, which is a pretty good deal these days.
https://www.rockauto.com/en/moreinfo...40757&jsn=2165
