02 jag xj8 jack stand points
#401
Rock auto has the idler pulley starting at $5 bucks
https://www.rockauto.com/en/catalog/...er+pulley,6956
#402
Hi CK I seen that but it's just a plan idler pulley I can pick that up locally for 12$ , I didn't know how important that Ridge ,Raised edge was don't need the belt flying off.
Going to try and push the old bearing out ,if it's not rusted into place it should give...
it's the same size , dimension as the tensioner pulley but with that raised end...
#407
#413
I had my local, very expert and long-time-trusted transmission shop, do a transmission fluid and filter change when they installed the Transgo pressure relief valve on my car two years ago. At my insistence they did a follow up full change of fluid a year later. Everything has been fine since.
#418
#419
Hello guys Hope Everyone is staying safe..
No licking shopping cart handles!
Question how typical is it for these lug nut to rust away to almost nothing, no threads or half the thread gone?
it took 2 days to get all 4 wheels off I have 9 lugs that are shot they just spun, I had to use a scissor jack and a length of 2 by 4 to put pressure on the wheels while I unscrewed the lugs. Plus hammer a socket onto most of the lugs because some JO must of used the wrong socket...Studs seems ok.... grrrr. Never ending fun with this project.
