02 jag xj8 jack stand points
Old 06-18-2020 | 05:38 PM
Carnival Kid's Avatar
They are quick connects, but a complete PITA to get to.
  #482
Old 06-18-2020 | 06:13 PM
Mrjay622's Avatar
All I can say is , Dangelous may the force be with you....
  #483
Old 06-18-2020 | 07:29 PM
Because I don't have a lift, and because I'm too old to be crawling under cars on jackstands, and because my hands/arms won't squeeze through the "space' to get to the fuel tank lines, when my fuel pump went out I bought the parts and took the car to my trusty local indy shop. For $360 labor it was worth every penny!
  #484
Old 06-18-2020 | 07:31 PM
Highhorse's Avatar
The tank will have to come forward....a friend is useful, its a tight fit.
...disconnect the 2 fuel lines under the car. You can use AC quick releases, if they don't work, we'll discuss that then.
...undo the fuel filler hose and vent hose.
...undo the retaining straps.
...place (2) 2x4's or similar, cut to length, to slide the tank forward over the battery and spare well.
...you only need to bring it out about 3'.
...install reverse of removal.
  #485
Old 06-18-2020 | 07:48 PM
Mrjay622's Avatar
Hi there HH....
I looked once I reached in i can see and feel the lines I can see part of it just looks like rubber lines pressed onto the metal lines.. Didn't see or feel any kind of quick connect.
could just be my arms didn't squeeze in far enough. . Either way that's one tough spot to work in .... you'll have to do it my feel,touch....
or break out the Sawzall and make your own access.
  #486
Old 06-18-2020 | 08:56 PM
Highhorse's Avatar
I did my fuel pumps 6 yrs ago, those fuel lines were a bear on mine. Folks post about their bad experiences, so that's the ones you'll find.
I also forgot to put on that list, ...put back of car on ramps. To get to the lines....once I got my lines out, I got the jack, blocked the front wheels, ..and took out the ramps, dropped the rear down to slide the tank back easier.
If you hack that rear deck, your asking for a rattle point to be made.
  #487
Old 06-18-2020 | 10:12 PM
Mrjay622's Avatar
That's so unreal... What were they thinking!
Don't worry I wouldn't really hack into the car...
I've done some searching ,Your right about the horror stories. Not much on very successful fuel pump removals.
oh well it is what it is...
Thanks for sharing.
  #488
Old 06-19-2020 | 01:41 AM
dangelous's Avatar
Yeah and considering the only thing I’ve ever done to a car is take the plugs out I’m not overly confident but I’ve worked on machines at work so how hard can it be..... famous last words..... it’s 7:30 am here so off I go......
  #489
Old 06-19-2020 | 08:35 AM
dangelous's Avatar
Got the left fuel line off the tank pretty easily but the line That goes to the filter won’t come out, can’t even see what I’m doing but can just get my hands in, tempted to buy a replacement pipe and replace it once the tanks back in but can’t find one anywhere, sng Barrett claim it’s no longer made
  #490
Old 06-19-2020 | 08:51 AM
Mrjay622's Avatar
I think you'll get done.
Take your time step away went you run into a problem , and now you know highashorse. Has done it maybe he'll chime in with some insight.
Wish I could see those connections.
Good luck and keep at it....
  #491
Old 06-19-2020 | 11:19 AM
dangelous's Avatar
Finally got the second one off! Fuel tank is ready to come out, tomorrow job now as It’s raining now
  #492
Old 06-19-2020 | 12:30 PM
Mrjay622's Avatar
Good Job!!!
Glad you got it... Now take pictures of everything and share it with all those that may need to do this one day....
Very good news....
  #493
Old 06-19-2020 | 12:32 PM
dangelous's Avatar
Hahahahaha unlikely 😂😂 I’m not one to follow! Been using a few guides on here and a guy on YouTube, working so far 😂
  #494
Old 06-19-2020 | 12:37 PM
Mrjay622's Avatar
Any work around you used or figured out would be useful information.
just saying. ..
  #495
Old 06-19-2020 | 12:41 PM
dangelous's Avatar
Only thing I’d say is jack the car up as little as possible to pipes are closer, I lowered it by one notched and made a difference, but slender hands and arms and luck and needle nose pliers did the trick getting the removal tool on that second line, just hope I remember where everything goes when it comes to putting it all back together! How’s your jag looking at the moment?
  #496
Old 06-19-2020 | 12:50 PM
Mrjay622's Avatar
Your right about Slender hands/arms.. I reached up under my car I could just touch the line i couldn't move around enough to find or reach the quick disconnects.
My car is just resting in the garage still on jackstands.
I may put the wheels back on it today... maybe. lol
So many other things that need to get done...
  #497
Old 06-19-2020 | 12:52 PM
Mrjay622's Avatar
Your in Great Britain?
  #498
Old 06-19-2020 | 01:08 PM
dangelous's Avatar
Yeah Northumberland, there’s no quick release connection you have to use a tool like this, bugger to get on 😂
  #499
Old 06-19-2020 | 01:30 PM
Mrjay622's Avatar
Ok thats nice. When your done take a drive over .... we'll check out your work...
I'm not sure what those are called but I consider them the tool for the quick connections.... Too lazy to research it....
  #500
Old 06-19-2020 | 01:50 PM
dangelous's Avatar
They are actually for air con pipes but apparently work all the same, and I can vouch for that 😂 yeah hopefully she’ll be running this weekend, then I’ll come over the pond 😂
Quick Reply: 02 jag xj8 jack stand points
