02 jag xj8 jack stand points
Old 06-19-2020 | 02:17 PM
Mrjay622's Avatar
A quick search, fuel line / AC Quick disconnect tool.
Just gald you got it off. What a savings ...
I know on my car the pump and fuel filter was replaced by a dealer for over 1400$ or 1133.17 GBP and that was 6 years ago....
let me know when your On your way I'll put up a spot of tea.....
  #502
Old 06-19-2020 | 02:22 PM
Highhorse's Avatar
Your in great position dangelous, ...its not totally easy from here, but the bear was getting those lines out and the others uncoupled. You'll have to work back and forth, a little at a time at first, the tank to get it out...that's where the friend comes in handy. The tank itself is quite lite for its size, its the fuel inside that makes it cumbersome.
  #503
Old 06-19-2020 | 02:23 PM
dangelous's Avatar
Hahahahaha outstanding! Make sure it痴 Yorkshire tea!
  #504
Old 06-19-2020 | 02:26 PM
dangelous's Avatar
Thanks HH I had the tank half out before the rain so not overly worried about that! It痴 the cue pump replacement I知 worried about now 😂
  #505
Old 06-19-2020 | 02:29 PM
Mrjay622's Avatar
Don't know how great of a position I'm in ,this car Sat for 3,4 years before I rescued it..
fuel was like varnish injectors plugged up ,just a mess... everytime I turn around something else is getting replaced. Ugh! Hasn't been on the road since I started this post. Don't even know if it's worth it yet...
  #506
Old 06-19-2020 | 02:34 PM
Mrjay622's Avatar
All I have for tea is a Lipton tea bag I found in the kitchen behind the stove when I bought this place... Looks ok to me...
  #507
Old 06-19-2020 | 02:36 PM
dangelous's Avatar
I値l bring my own then just in case! And you値l have that it up and running in no time, I致e no doubt
  #508
Old 06-19-2020 | 03:03 PM
Mrjay622's Avatar
It's warming up , I want to check the transmission fluid level one last time before I drop it..
  #509
Old 06-19-2020 | 05:41 PM
dangelous's Avatar
Looks great!! Still didn稚 know where to use my trolley jack on it! Couldn稚 use the standard jack points as the jack got in the way of the axle stands! So had to use the jaguar jack!
  #510
Old 06-19-2020 | 05:47 PM
Highhorse's Avatar
MJ has quite an investment in floor jacks I see. I think he's keeping Harbor Freight in business by himself...lol
  #511
Old 06-20-2020 | 06:18 AM
Mrjay622's Avatar
lol. YOUR SO MEAN!
1st poor mint sauce now my 45$ jacks....
smh.
  #512
Old 06-20-2020 | 07:03 AM
dangelous's Avatar
Fuel pump changed, bit fiddly but not bad, hope everything is all correct, I致e a clip left over and no idea where the hell it came from, any ideas? Can稚 imagine it痴 off the fuel
  #513
Old 06-20-2020 | 07:34 AM
Mrjay622's Avatar
That's good news. ..
Sorry No Idea where that came from...
Never having the pleasure of replacing a fuel pump on a jag...... go back and few post CK put up a diagram of the fuel tank and pump parts... maybe that may help?
Keep up the good work...
  #514
Old 06-20-2020 | 07:38 AM
Mrjay622's Avatar
I don't see it here... maybe # 3
  #515
Old 06-20-2020 | 09:43 AM
dangelous's Avatar
Potentially, I知 sure I値l find out eventually!! Appreciate the diagram!
  #516
Old 06-20-2020 | 09:50 AM
Mrjay622's Avatar
Let's hope you find out before you put all back together. And it's not something that belongs in the tank....
Good luck. .. Keep moving forward. ..
  #517
Old 06-20-2020 | 10:04 AM
dangelous's Avatar
That was my fear but all there is is one pipe which definitely had a clip on! I知 sure I値l find it!!
  #518
Old 06-21-2020 | 06:34 AM
Highhorse's Avatar
...or its off of something totally unrelated and you just happened to find it doing this and you knock your brain out just to realize that.
  #519
Old 06-21-2020 | 06:42 AM
dangelous's Avatar
Unlikely as I put all the bits In one place, filter going back on later so we値l what happens 🙏🏻
  #520
Old 06-21-2020 | 08:37 AM
Highhorse's Avatar
That's a smart thing, have you reviewed any differences in the old pump vs the new one? Say maybe what was previously a 2 piece slip clip on a joint, is now a pressed piece single assembly?
I reviewed this as best I could to no answer (its an XK8, but the setup is the same). Perhaps you can see something dangelous? In either case if any of you were interested why the fuel lines are such a PITA, there are some excellent camera shots showing why... JagRepair.com - Jaguar Repair Information Resource
Quick Reply: 02 jag xj8 jack stand points
