02 jag xj8 jack stand points
#501
A quick search, fuel line / AC Quick disconnect tool.
Just gald you got it off. What a savings ...
I know on my car the pump and fuel filter was replaced by a dealer for over 1400$ or 1133.17 GBP and that was 6 years ago....
let me know when your On your way I'll put up a spot of tea.....
#502
Your in great position dangelous, ...its not totally easy from here, but the bear was getting those lines out and the others uncoupled. You'll have to work back and forth, a little at a time at first, the tank to get it out...that's where the friend comes in handy. The tank itself is quite lite for its size, its the fuel inside that makes it cumbersome.
#505
Don't know how great of a position I'm in ,this car Sat for 3,4 years before I rescued it..
fuel was like varnish injectors plugged up ,just a mess... everytime I turn around something else is getting replaced. Ugh! Hasn't been on the road since I started this post. Don't even know if it's worth it yet...
#513
#520
That's a smart thing, have you reviewed any differences in the old pump vs the new one? Say maybe what was previously a 2 piece slip clip on a joint, is now a pressed piece single assembly?
I reviewed this as best I could to no answer (its an XK8, but the setup is the same). Perhaps you can see something dangelous? In either case if any of you were interested why the fuel lines are such a PITA, there are some excellent camera shots showing why... JagRepair.com - Jaguar Repair Information Resource
