02 jag xj8 jack stand points
#41
Received 1,798 Likes
#42
I hope so... done all that stuff before I broke my neck...
We'll see....
Right now I'm having trouble figuring out how to get the thermostat housing off the two rear bolts are up against the intake no room to get a socket down there and no room for a small open-end wrench. Short of removing the intake manifold off what's the trick/secret? ???
We'll see....
#43
Some struggle with a specially bent crow's-foot-type wrench and have succeeded.
Some have broken the plastic tower piece by piece.
Some owners have loosened the bolts holding the intake manifold and lifted the front just enough to get to the rear tower bolts. The intake manifold hinges on a bolt at the throttle body.
Some have removed the intake manifold, at least if you do this you can replace the two heater hoses that run under the manifold, and the 3-way connector, while you are in there.
#44
Agreed, the only difference is that Jaguar decided not to use keyways on its cams, hence the need for the special timing tools. It makes it a case of being very patient, and very certain, that you have things in the correct position during disassembly and, more so, during assembly.
#45
MrJay, here is a link to a brief how-to if you decide to replace the under-manifold heater hoses and 3-way connector ......giving you easy access to the thermostat tower bolts. These heater hoses and the 3-way connector are known to leak at the age our 308s are at.
https://www.docdroid.net/yUGg4Gg/jag...s-manifold.pdf
#46
This post started with me looking to safety jack it up and support it on jack stands.
Just to do breaks,rotors wheel studs and maybe some sand blasting and painting of rusted parts while I'm there...I knew the sparkplug wells were leaking and filliing with oil causing misfires that was going to be an easy fix... Not get this involved. This car was only bought as a project for me and my son then let him have it, the car is in really nice shape and kinda worth saving. I personally have no real interest in the car... But I have it now im also retired with time on my hands, So in memory of my son, I guess I'll do what I can and see from there where I end up...
Again as always guys Thank you I really do appreciate All your help...
#47
#48
And, you will have saved another X308.
Hang in there MrJ, we will be with you all the way.
#49
#50
#51
Just be sure you got the correct chains, Jaguar changed to Morse style chains late in the range, I got a wrong set one time.
Should be determined by the engine number, and a adequate parts supplier.
#52
#53
OK, basically the engine number can be determined if you give them the complete VIN, and based upon the engine number they can determine the correct parts for that MY.
If the engine is replaced though ...
And those are the traditional style chains, I think they were used till end of 2002 or so.
I just looked up as a reference, I pay some 400 (British Pounds) for a full set of tensioners / chains / guides / seals / gaskets), all from British Parts in the UK, and all coming from Jaguar Parts (wherever they are made ...).
Then mostly need some other parts as sump seal, hoses, or whatever is needed.
#54
MrJay, the morse-type chains were introduced very late in the X308 production, either very late 2002 or 2003 only.......and used on the subsequent X350 models, but you have the standard style, single-row chain. Your cam-cover-removed-pic shows the standard chain which will be what you receive in your kit.
#55
#58
#60
