'02 XJ Sport squeel at start up
Hi,
just bought this beatiful '02 XJ Sport and a problem already..ughh..
When it's cold out there is squeels when you start it..It does it till you start driving and bit longer sometimes now..It can be really loud too..I've also had a once a a very short rattle,but for a second or two only...What is it? I've read the forum and found similar problems, but still no answer yet..Tensioners (hope not), no warranty, or something else, does anyone know? it's kind of scarry reading what has happened to people, and how much it costs..!
thank you
thank you
thank you very much for your fast response..!
I just hoped someone's going to have a definite answer, thought it might be a common problem on XJ8's..No Jaguar techs around here (Lincoln,NE), not many want to even take a look at it..! Does the Jaguar factory recommend at what mileage the tensioners need to be replaced? Are they expensive to replace before they go really bad?
thank you
thank you
Guest
Posts: n/a
Sharp car sashaunl!
I just purchased a 2002 as well. So far I love the car. Ironic that I noticed the same squeel from my car the morning that I read this post. However, it was 10 degrees outside. At that temperature I wouldn't be surprised if any car has a squeel. But since you mentioned that it continues after you start driving and it is pretty loud...maybe you should have it looked at.
is this squeal a screeching sound or a howling sound. If is sounds like a Howell it is probably the bearing on the as compressor clutch. They will do that in very cold weather and will continue to Howell until the bearing warms up and the grease softens. You could try some belt dressing spray on the belt. If the nose stops than you will know that its the belt and you need to replace it. As fare as the rattle, thatmost likely is from the timing chain and is common when first starting up. I would recommend using a full synthetic lubricate like mobile-1 in stead of motor oil. It is a much better lubricate will give you max chain and engine life. I use it in my 98 xj and have over 110,000 mile with no engine problems. I have used it for year in many cars and have gone 300,000 miles with out chain or engine overhauls.
Hi, is that squeel a sound like a screech or a howling sound. If its a Howell it is probably the ac compressor clutch bearing. They will do this in very cold weather. It will stop after the bearing warms and the grease softens. You could also try some belt dressing spray on the belt. If the nose stops it the belt and you will need to replace it be for it breaks.
As for the rattle it sound like the timing chain. Its not uncommon for it to rattle a few second when starting the engine. I have 110,000 on my 98 xj and I have never done anything with the chain. However I would recommend using a full synthetic lubricate like Mobil-1. this is what I use and have used in many cars that have gone 300,00 miles with no engine overhauls. Synthetic is a much better lubricate that doesn't break downlike motor oil.
Guest
Posts: n/a
WTB[NorthEast]: X-Type Sport Wheels
Whitnessmouse
09-04-2015 11:09 AM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 09:38 AM
