02 xj8 fog light replacement
RE: 02 xj8 fog light replacement
Dealers need revenue, that's why!
To change bulb:
Remove undertray
Disconnect bulb multiplug from the bulb
Rotate bulb, remove, replace (don't touch glass part of bulb with fingers - if you do, clean it with denatured alcohol to prevent hot spots and premature bulb failure).
If you need to replace the entire light, just 3 screws to remove.
Cheers!
________
1999 XJR
To change bulb:
Remove undertray
Cheers!
________
1999 XJR
Will P
08-27-2015 06:52 PM
