02 xjr
02 xjr
Gentlemen:
Had an intermittent ABS light so took unit out and took it over to a place to rebuild. Install unit and get INCORRECT PART INSTALLED, TRANSMISSION FAULT, P1720,P1637, Trans stuck in first, speedo doesn't work.
I called ASI (who I should have sent this to in the first place) and was informed that the P codes were picked up by engine computer before they converted to ABS code. Keep in mind car ran perfect before ABS repair.
Any ideas?
Thanks to all.
Any ideas?
Thanks to all.
