03 VDP driver window mirror control..Help Please!
Ok, I couldn't find anything like this anywhere, so I'm looking for some help. My VDP had the driver door lock / latch system fail with the door closed. Removed the door panel, (with the door closed, not easy but doable). Replaced the latch assembly, good to go. As I'm putting the door panel back on, I test the windows, mirrors, etc. Nothing works, except the right rear passenger window button works the driver door window only...nothing else works from the panel. The connection is straight-forward, and keyed, so even I can't screw that up. All of the other doors / windows work as they should. Any ideas? Is it just a coincidence and the control module is bad? Any thoughts would be appreciated.
Jhartz (09-10-2014)
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
