03 xj8 range error message
Gentlemen:
Well wife forgets to fill gas tank till almost out(no don't ask me how she didn't see gauge/light).
Here's the problem she put about half a tank in, starts car no read on gauge for ten seconds then needle jumps to correct reading then drops to E. When I check for range message now reads RANGE ERROR. Any ideas? I sure hope i don't have to change the sensor in the tank, is true you have to take out the gas tank?
Fuel Tank R&I also Parts list - Diagrams & Photos
Hello
Update - AllData DIY gives this safety recommendation "Relieve the fuel system pressure prior to disconnecting fuel system components". Also here are 2 other threads that have posts on the fuel tank and fuel level sender:
https://www.jaguarforums.com/forum/x...001-xjr-37754/
(look at post# 3 for TSB)
https://www.jaguarforums.com/forum/x...sonable-34983/
Our own experience: local Jaguar Dealership replaced the Fuel Pump and Lead link that was
inside our 2001 XJ8 Fuel Tank in April 2008. I am not sure if they removed the tank.
They charged 3.5 labor hours @ $100 per hour plus the cost of the parts and sales tax.
The 3rd Party warantee company paid for everthing except the lead link part of the bill.
I am not sure if changing the Fuel Tank Sender is a DIY job. There seems to be some
serious safety issues and cautions in the JTIS instructions about Fuel pressure procedures.
Well, I wanted to make sure that the Safety concerns were noted in this thread.
Here are a bunch of PDF files that will provide some of the information on the Fuel tank -
Diagrams/Photos/Instructions (first PDF file of Diagrams & Photos - page 1 has view of front of tank after
trunk lining is removed & shows the access to the sender near the bottom of tank):
Jaguar XJ8 Fuel Tank Diagrams & Photos.pdf
Jaguar XJ8 Safety Instructions.pdf
Jaguar XJ8 Battery R&I.pdf
Jaguar XJ8 luggage front trim R&I.pdf
Jaguar XJ8 Drain Fuel Tank.pdf
Jaguar XJ8 Fuel Tank Level Sensor R&I.pdf
Maybe some of the forum experts will give some of their excellent advice on these procedures.
Jim Lombardi
Jim Lombardi
scooternva
19
10-27-2015 02:14 PM
mls0036
10-17-2015 10:03 AM
