03 XJR-How to remove the coolant crossover pipe
Hello
Here is an Diagram of a XJR Engine showing Supercharger and Cooling componets (to maxiumize the thumbnail image - put your mouse pointer on the image then double click your mouse):
![03 XJR-How to remove the coolant crossover pipe-outlet-pipe-assembly_page_1.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/12161d1480965992t-03-xjr-how-remove-coolant-crossover-pipe-outlet-pipe-assembly_page_1.jpg)
You might be able to point out the part on the diagram that you are trying to remove.
Jim Lombardi
Jim Lombardi
Hello
Attachment 12161
Jim Lombardi
Attachment 12161
Jim Lombardi
Hi
Update: I created a new thread for the Supercharger Removal and Install.
I thought maybe other forum members might need it in the future and putting it in a separate thread will make it easier to find later.
https://www.jaguarforums.com/forum/j...f-files-58889/
The components between the reference pointers 6 (Supercharger unit) and 7 (Supercharger pulley) is Coolant Outlet Assembly per JTIS that includes the Coolant Outlet Duct and Termostat Cover -
the JPEC calls the assembly - the Outlet Pipe also lists the components as the Thermostat housing (Part# AJ83968 or AJ81981 depend on engine number) and Thermostat cover (Part# NCC2245BC).
Here is two diagrams of the same assembly I copied into this JPEG file from the JTIS and JEPC (you may want to use the browser zoom level up to 150% to view this JPEG):
![03 XJR-How to remove the coolant crossover pipe-outlet-pipe-assembly_page_2.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/12164d1480965992t-03-xjr-how-remove-coolant-crossover-pipe-outlet-pipe-assembly_page_2.jpg)
Do you want the instructions just to remove the Coolant Outler Assembly or the entire Supercharger?
Jim Lombardi
Jim Lombardi
Hi
Attachment 12164
Jim Lombardi
Attachment 12164
Jim Lombardi
Hi Vipa
The Coolant Outlet Assembly consist of 2 parts - the Thermostat Housing Cover and the Coolant Outlet Pipe.
Here is the PDF on the Thermostat Housing Cover showing parts diagram:
https://www.dropbox.com/s/pr40evamr6...20Cover%29.pdf
And the PDF of the Coolant Outlet Pipe - removal/install instructions with illustrations:
https://www.dropbox.com/s/n967ibdmxf...er%20R%26I.pdf
Jim Lombardi
Jim Lombardi
aholbro1
08-05-2021 05:02 AM
Jaguar Forums Editor
Jaguar Press release
09-04-2015 09:18 AM
