03 XJR with rainwater in gas fill well
Once again- I am hoping for input from the collective wisdom of the 308 team. We have a new (to us) 03 XJR that collects water in the well surrounding the gas fill neck in the back lid- no obvious weep/drain holes upon close inspection. No gasket under the lid or well rim. Any thoughts would be appreciated....
there should be a perforated tube thing sticking up from the corner close to the outside and back of the car, it could be missing but there should be a pretty sizeable drain hole there.
top left here https://www.jaguarforums.com/forum/a...062257_hdr.jpg
dmpsqrd (10-27-2016)
The well has a drain. When new they have a small periscope screen. It's a small cylinder with holes that allows water to flow into a tube -- the holes stop the tube from clogging.
Your periscope must be missing and dirt has accumulated in the tube -- a garden hose will clean it out .. the periscopes used to be available from the parts .. not very expensive.
dmpsqrd (10-31-2016)
